chain joining link won't fit: time for new chain?
cooperplace
Postby cooperplace » Fri Feb 24, 2023 6:05 am
My 900S2 (I know, it's like 2 singles) has an o-ring chain, it was on it when I bought it, that looks to be in good condition, no stretch at all for example. I had to break it for engine removal and refit, so i bought a joining link, correct size, 530. But the joining link won't fit in. Is this time for a new chain? Or is it OK to press in a joining link?
Advice from the wise much appreciated.
Sorry for a V-twin Q but the quality of advice here is so much better.
be nice, I'm not very bright.
Re: chain joining link won't fit: time for new chain?
Postby Duccout » Fri Feb 24, 2023 7:54 am
We need more info! Why will the link not fit? Are the pins too large? Are you sure that it is the correct link? It should slide straight in......
cooperplace
Postby cooperplace » Fri Feb 24, 2023 12:12 pm
I don't know why it won't fit. It is the correct -according to label- new pin. Yes it should slide in, but it doesn't.
Postby Duccout » Fri Feb 24, 2023 12:55 pm
I doubt that you need a new chain.
Dave354
Postby Dave354 » Fri Feb 24, 2023 1:49 pm
Hi, my advice is to measure the pitch of the chain ( between centres of the pins ) and the pitch of the link…. If they are the same then check the pin diameter. If that’s the same, it may need a bit of pressure using a chain tool ( or small clamp ) make sure the new link is free to rotate.
Good luck
Dave
Sebring 350 based Ducati
Triumph Tiger 1200
Cornwall, UK
Postby Ventodue » Sat Feb 25, 2023 1:25 pm
Message deleted
Postby Ventodue » Sat Feb 25, 2023 1:27 pm
cooperplace wrote:I don't know why it won't fit. It is the correct -according to label- new pin. Yes it should slide in, but it doesn't.
Do you have a set of calipers (or a micrometer) to do a comparison measurement of the pin diameters, new link vs. old?
'Cos at the end of the day, that's all that matters, regardless of what the label on the packet might say ...
cooperplace
Postby cooperplace » Mon Feb 27, 2023 11:03 am
yes I do. That's a very good idea, thank you.
Why didn't I think of that? Must be getting old-timers disease.
cooperplace
Postby cooperplace » Tue Feb 28, 2023 1:05 am
Turns out there's a ten thou difference in pin diameter. Definitely time for a new chain.
