Engine case cut away?
Ron C
Postby Ron C » Sat Jan 28, 2023 3:49 pm
I picked up a 250 MK3 engine yesterday with some of case cut-away. The gentleman I got it from. Said thats what is done in racing community. Thought odd. It was cut out with care.
The engine does not have rev counter and had a SSI 27 carb on it.
Already in basement and apart. Plans are to put on my Monza 250.
Ron
Re: Engine case cut away?
Postby blethermaskite » Sat Jan 28, 2023 4:43 pm
Very common on race prepped engines.......usually the gear change cover is also cut away ,all done in theory to gain easy access to the clutch cable for a quick replacement, also a bit more access for chain and gearbox sprocket swops and it removes a little weight off the motor :roll: ??.
IanHood
Postby IanHood » Sat Jan 28, 2023 5:48 pm
You can see you usual cover cutaway in this photo of my 450 engine (before being rebuilt)
Users browsing this forum: No registered users and 71 guests
