'74 450 Jupiter Airbox - What is correct?
Alex450Jupiter
Postby Alex450Jupiter » Thu Jul 28, 2022 1:54 pm
My '74 has the fiberglass "kidney" side covers and the right side encloses the air filter. Right now the filter element is held in place by its open top being pressed against the inside of the fiberglass cover. This can't be correct and I assume I should have a "thinner" air filter element held on by a solid plate with a bolt/nut to that center bracket, all hidden under the cover. Can someone with this model confirm the correct set up? Are my missing parts available? Thank you.
Alex450Jupiter
Re: '74 450 Jupiter Airbox - What is correct?
Postby Alex450Jupiter » Thu Jul 28, 2022 5:18 pm
I’ve been scanning parts sites and do see a thinner element for bikes with covers, so I do believe I am missing the center plate and hardware. I don’t see those parts (yet anyway) so if anyone knows of them please let me know! Otherwise I can easily fab up something as this is hidden.
Postby ducwiz » Fri Jul 29, 2022 3:01 pm
From the 1974 parts catalog (450 SCR section) you can see what's missing. The center bolt or stud in the airbox is also missing, but not depicted on the posted catalog page. Imho, the filter cartrídge is the same as used in the 750 GT, FIAMM 6179. This page https://www.inlinefilters.co.uk/info/xrefs/Fiaam.htm gives a cross reference for FIAMM filters, finally shows https://www.inlinefilters.co.uk/Filters ... IN-FA10572.
Alex450Jupiter
Postby Alex450Jupiter » Fri Jul 29, 2022 4:58 pm
Thank you Hans. I'm a new owner, so do you know of sources of used/salvage Ducati parts where maybe I can find cover 0093.27.492? I'll keep looking...
IanHood
Postby IanHood » Mon Aug 01, 2022 12:12 pm
I'm not sure that parts diagram is correct. I think you actually want one that looks like this:
https://www.ducativintagestore.com/air_ ... 1st_series
Postby Ventodue » Tue Aug 02, 2022 9:08 am
No, that's one of these, part number 0690.91.755. As fitted to what the Italians often refer to as the First Series (Prima Serie) of Scrambler.
Here it is in place:
What Alex is after is the air filter for a Second Series. It is different from the First Series and is hidden behind a big plastic side cover like this:
Postby Ventodue » Tue Aug 02, 2022 9:13 am
Alex450Jupiter wrote:Thank you Hans. I'm a new owner, so do you know of sources of used/salvage Ducati parts where maybe I can find cover 0093.27.492? I'll keep looking...
Alex, try Maurizio or Ombretta at Ducati Vintage Store. They were (and may still be ...) the leading lights behind Gli Amici dello Scrambler for many years.
Super people, always willing to help.
Postby ducwiz » Tue Aug 02, 2022 8:17 pm
Yes, Ventodue's advice is certainly the best you can do to find out which parts are really missing.
Users browsing this forum: No registered users and 176 guests
