Horn
Re: Horn
Yes, they can. They're very simple devices - plenty of info on Tinternet; just type in, 'How does a high frequency horn work'. It's often just the points inside. (The screw on the back acts on the points to compensate for wear).
Is it worth it? Ah, that's a different question ...
Fun, if you like fiddling. But if you just want to get street legal, it's might be better to simply fit a Chinese one off eBay or wherever. More reliable, less energy consuming and certainly louder ...
Btw, to the best of my knowledge, Ducati singles didn't use Bosch units, but CEV (various models); and possibly Aprilia. But, as always, I stand to be corrected.
frankfast
Re: Horn
Thanks Ventodue. The horn I have is supposed to be original equip on my F1 which is the only reason I was interested in it. I have a cheap aftermarket item that works fine but I wanted to know if anyone has taken one of these things apart. It looks sealed to me and would be destroyed if I tried to open it. It also weighs twice as much as the aftermarket one.
Re: Horn
I haven't had much success with horns.
An early mistake was to use silicone gasket paste instead of the main gasket, and I think it was pretty good at reducing sound.
Keeping water out is important of course.
Voxbell is another brand of horn I've seen on Ducatis.
Re: Horn
frankfast wrote:Thanks Ventodue. The horn I have is supposed to be original equip on my F1 which is the only reason I was interested in it.
Got you. Does it look like this?
These Bosch units were original fit on late bevels (MHR, Dramah etc) and also on the 500 and 600 Pantahs, all the time under part number 0801.38.050 (0801. is the Dramah model code).
So very likely fitted to the F1 too, but I haven't been able to confirm the part number for the F1.
Personally, if it ain't working, I don't think you have anything to lose in trying to carefully prise the thing apart ....
Re: Horn
Jordan wrote:An early mistake was to use silicone gasket paste instead of the main gasket, and I think it was pretty good at reducing sound.
Yep. In the absence of proper gasket paper, a bit of thick paper is all that's needed.
Jordan wrote:Voxbell is another brand of horn I've seen on Ducatis.
Ah, good point. In 6 volt as well as 12v, Jordan?
Also, I recall some of the 750 & 860 bevels had "Belli" horns. ("Who they?", you might well ask ...)
Re: Horn
frankfast wrote:By the way, The F1 has an elephant on the tank. So it is a Cagiva part number, not Ducati.
Ah ... a 1986 model then. The only F1 parts book I have is the 9-85 edition, still under the Ducati imprint.
I've never seen a Cagiva F1 parts list.
