Kickstart park position
Geordie
Postby Geordie » Tue Aug 24, 2021 5:51 pm
I will eventually get this thing started when I sort the kickstart :lol:
The leaf spring, despite being doubled at some time in its life, was not doing its job.
I sourced a modification kit for the later bridge and coil spring. Now fitted.
Leaf or coil, I get the kickstart return spring not lifting the ratchet cog because it only returns the kickstart to just before the park position.
Is this a design feature or a problem needing a fix? If so, what is it :?: :?:
One piece of info: the plate that that engages with the ramp on the ratchet cog was chewed. I added some weld and filed its ramp to a 45 degree angle as that of the ratchet cog - couldn't see a reason for it to be any other angle. :|
Geordie
Re: Kickstart park position
Postby Geordie » Wed Aug 25, 2021 3:07 pm
Problem solved - kickstart return spring had relaxed since 1962.
I unrelaxed it to look like the parts pictures of replacements.
Tomorrow dedicated to starting after rebuild - what can possibly go wrong :?:
Users browsing this forum: No registered users and 84 guests
