250 Narrowcase - repairing damaged case
DesmoDog
Postby DesmoDog » Thu Aug 19, 2021 8:50 pm
Greetings,
I recently retired and am starting to take a look at my long dormant projects to remind myself what they need.
One of them uses a 250 narrowcase engine. Somewhere along the way the engine was damaged;
I'm guessing that this isn't the first time this has happened and I'm wondering the best way to fix it? I haven't even figured out what that feature is there for yet but I'm hoping it's a relatively easy fix. This will not be a show bike, it won't bother me in the least if the repair is obvious.
Comments?
Geordie
Re: 250 Narrowcase - repairing damaged case
Postby Geordie » Fri Aug 20, 2021 7:56 am
It's a plug in the oil pump pickup gallery leading from the oil filter. A part of the manufacturing process.
I'd weld it.
But I would await confirmation from another on here as I have been wrong in the past!
Postby LaceyDucati » Sat Aug 21, 2021 9:11 am
Agreed with Geordie, it is a plugged oil gallery which is part of the manufacturing process. There is no particular need to remove or access the gallery and therefore a safe acceptable repair would be to weld it over. There is plenty of material in the area and little to chance of distortion. I would suggest cleaning the cases thoroughly and lightly cleaning the immediate area with a small carbide to expose clean aluminium. It would be best welded professionally by Tig welding and the casing should be preheated before welding for best results.
DesmoDog
Postby DesmoDog » Sat Aug 21, 2021 3:01 pm
Excellent news, thanks guys!
