Spark Plug Gap With Electrex World Ignition
Postby Duccout » Thu Jun 10, 2021 1:28 pm
I'm guessing that this has been covered before, but I can't find it.......Does anyone know the recommended plug gap when using the Electrex World road kit?
Re: Spark Plug Gap With Electrex World Ignition
Postby themoudie » Thu Jun 10, 2021 9:21 pm
Aye Colin,
Nigel, I believe, uses 0.025" (0.635mm) and I have used that to good effect. I have also used 0.030" (0.762mm) as specified by Ducati for their EI system and again had no problems, to date. This is using the Electrex STK-169D ignition kit that I have fitted and which has similar components to other ignition systems manufactured by Electrex for Ducati singles.
If I have this incorrect, then I am sure that Nigel will correct me. ;)
Postby Duccout » Fri Jun 11, 2021 6:06 am
Bill,
I, too have been running 0.030" but I've no idea if that is right. John Carpenter of Mistral Engineering, who made the RITA systems for bikes, told me that bigger is better and recommended 0.030", and I know that modern cars run up to 0.040", but old Ducatis are anything but modern.
Dodge
Postby Dodge » Fri Jun 11, 2021 9:09 am
Mike Walker recommended 0.030" for the Ducati Electronica ignition on the Mk3 widecase singles.
tonyduc
Postby tonyduc » Wed Jun 16, 2021 9:27 pm
This is good to know. I just finished installing the Electrix EI in my 67 Mark 3, it started right up on first kick and ran great with the factory recommended.013” - .017”. But I’ll try increasing to.030”. It’s great not fiddling around with points and the mechanical advance mechanism !
1967 Ducati 250 MK3
1976 Moto Guzzi T3
Former:
1969 Ducati Scrambler yellow
Postby Duccout » Thu Jun 17, 2021 9:30 am
Update: Electrex World told me to use the standard Ducati gap, so I assume that means 25 thou.
Users browsing this forum: No registered users and 85 guests
