Frame Work
Mark3Cam
Frame Work
Postby Mark3Cam » Tue Feb 16, 2021 4:18 pm
Hey guys, been awhile but getting close to wrapping up my frame work. The rear hoop had been chopped. After many discussions online here to figure out my mystery bike, I ruled out the Scrambler possibility after looking at top rear shock mount location - as was pointed out to me here on the forum. I decided to go with it being a Mark 3 350 as it turns out there was no registration to be found in a recent search....moving forward now! It wouldn’t be a full resto back to OEM spec but happy how she is looking. I took the seat from a 95 Triumph Thunderbird and took 4” out of the center, cut and shaped foam and re-worked the vinyl. Tank is from a 68 Scrambler, needed some fabrication on headstock mounts.
Re: Frame Work
Postby Eldert » Tue Feb 16, 2021 8:27 pm
did you remove the steering lock on the headstock ?
the bottomcup for the bearing balls looks like a very loose fit and might need some work
Users browsing this forum: No registered users and 159 guests
