Raised bars
Raised bars
Postby Bevel bob » Fri Dec 04, 2020 6:49 pm
Looking for a set of swan neck bars to replace the clip ons on my 250 with 31mm forks.Any Idea ?
Re: Raised bars
Postby Duccout » Fri Dec 04, 2020 8:04 pm
31mm is an odd size, you might have to shim out some 32mm bars. What about the type of clip-ons that can be adjusted for rake? You could adjust them flat so that your hands are not angled down. Alternatively, have you tried turning your clip-ons upside down and swapping them to the opposite fork leg? It makes them much more comfortable.
Re: Raised bars
Postby ranton_rambler » Fri Dec 04, 2020 8:14 pm
Put the other style top yoke on and then your choice of bars?
cooperplace
Re: Raised bars
Postby cooperplace » Fri Dec 04, 2020 9:18 pm
Duccout wrote: have you tried turning your clip-ons upside down and swapping them to the opposite fork leg? It makes them much more comfortable.
Interesting idea, I'll give it a go on the Vento; thanks.
be nice, I'm not very bright.
Re: Raised bars
Postby Duccout » Fri Dec 04, 2020 10:15 pm
I've been running my clip-ons like this for years. Because of the rake of the forks, they sit at a flat angle and give your wrists a much easier time.
Re: Raised bars
Postby themoudie » Sat Dec 05, 2020 1:46 am
Aye Bob,
They are a bit wide, but I can recommend the swan neck bars from Barleycorn Engineering: Barleycorn_Engineering_swan_neck_bars
I used to run standard clips-ons on the 450 MKIII, but after a spectacular spill in '78 they were replaced with cheap chrome clip-ons of varying lengths that often involved a fight with levers, switches and grips. I then started reversing/inverting a pair of clip-ons as Duccout suggests and that worked fine, but still a fight with fitting the controls.
I have never been able to find the alternative bar mounting top yoke supplied for Marzocchi forks on the later MKIII widecase models or else exchange them for gold! ;) So, after the current rebuild I tried the inverted bars again and following an accident in 2017 they were not so comfortable. After speaking with Simon at the Stafford 2019 autumn show, I purchased a pair of 35mm swan necks and they have given me a more comfortable riding position. Your 31mm stanchion size might cause problems, but I would talk with Simon before ordering to see if he can accomodate your requirements. Alternatively, his 'Comfort clip-ons' might suit.
Re: Raised bars
Postby Duccout » Sat Dec 05, 2020 7:49 am
They look good! Ducati used to offer swan-necked clip-ons, and I had them on my 450, they worked well. It is surprising what is available out there.
Re: Raised bars
Postby Bevel bob » Sat Dec 05, 2020 8:17 am
Hi All, I inverted my clip ons last year ,and it was a help. I have been offered a suitable top yoke to replace my smooth one and a set of bars too. I rather like the idea of the Barlycorn set up as it may ?allow me to keep the std alloy HL brackets ..the fork legs are 31.5 . It will mean all new cables however.. A light low bike may be all I can cope with in my 80's. Won't be long!!
Re: Raised bars
Postby Duccout » Sat Dec 05, 2020 9:20 am
Me too! I'm wondering how long I'll be able to ride my 900 bevel, assuming that I can still wheel it out of the garage!
Re: Raised bars
Postby themoudie » Sat Dec 05, 2020 12:19 pm
Aye Duccout and Bob,
If you require actual measurements, please drop me a line and I shall try to oblige.
Regards, Bill
Users browsing this forum: No registered users and 120 guests
