help finishing my 69 350 scrambler
richrd
Postby richrd » Sun Nov 15, 2020 10:26 pm
this bike has been sitting in the shop for about ten years and I pull it out once every year or so to work on it. Now its time to finish it.
`first question, i started pulling out pieces for the primary and in with the clutch parts was a shim. it measures 24.95 od, 18.3 id and .5 thick. any one know where it goes?
the original coil terminals are marked "1" and "14". which would be + and which -, or does it matter?
And on the rest of the wiring, should I just run the wires I need like I would on British bike? or try to make sense out the mess that fits in the headlight?
thanks, and keep after me to finish this thing.
cooperplace
Re: help finishing my 69 350 scrambler
Postby cooperplace » Mon Nov 16, 2020 6:51 am
I don't know about the scrambler, but my 350 Vento has a shim like that on the gear change.
be nice, I'm not very bright.
Postby Duccout » Mon Nov 16, 2020 10:12 am
Does it go behind the clutch?
Postby LaceyDucati » Mon Nov 16, 2020 7:14 pm
The shim is off the kickstarter shaft and goes on after the piece of tube immediately up against the primary cover, last part on before the cover.
richrd
Postby richrd » Tue Nov 17, 2020 3:45 pm
thanks. and I've decided to do my own wiring harness, and eliminate the mess in the headlite.
