Rear Hub Cush Drive NC V WC
Postby graeme » Sat Aug 15, 2020 4:47 am
Hello all,
I've been looking for a rear hub,,, now have one, BUT... cleaning up and replacing bearings..
The hub is of the late type with 4 fins.
The cush drive that came with the hub is the 1 6002 bearing type which I think is from a late narrow case ?
The later drive had 2 6004 bearings.
Q1, would this 1 bearing cush drive / sprocket carrier stand the torque from a 450 ? Ducati changed to 2 bearings for a reason.
Q2, will a 2 bearing cush / sprocket carrier fit the earlier hub ? I assume it will. But they are hard to get at a reasonable price.
Q3, will a cush / sprocket carrier from a 350 parallel twin GTL GTV fit the hub ?
Re: Rear Hub Cush Drive NC V WC
Postby graeme » Sat Aug 15, 2020 4:48 am
Postby graeme » Tue Aug 18, 2020 6:25 am
for future reference,
The cush / sprocket carrier from the late singles is part number 0690.80.240
The GTL 350 - 500 carrier part number it the same, so I ordered one from ebay. (heaps cheaper than single carriers)
GTL 350 parts manual shows the hub the same as the late singles
Hopefully it is the same, will let you know in a few weeks when it gets here from Germany.
Users browsing this forum: No registered users and 229 guests
