Valve clearances 175T 1957?
Postby Ventodue » Mon Jul 27, 2020 7:29 am
I'm posting this on behalf of a friend who is as confused as I am ... :?
I've had a trawl thru previous posts on the Forum without any luck.
What are the correct valve clearances for a 1957 175T? We have so found 3 references, i.e. a 125 owners manual; a 200 owner's manual; and the workshop manual for the 100/125/175/200 range, that say 0.05/0.07mm.
And 3 references, i.e. owners manuals for the 175 Sport; for the 200 range (a different manual from the previous); and (again a different manual) for the 125 that say 0.5/0.7mm.
So a ten-fold difference, presumably originating from an editor's slip-of-the-pen :o .
Can someone please put us out of our joint misery: which is correct?
TIA!
veloduke
Re: Valve clearances 175T 1957?
Postby veloduke » Mon Jul 27, 2020 4:56 pm
Hi
0.5 mm is 20 thou (0.020") so I can't see that being right, unless you want to hear the bike coming :) .
.05 mm sounds better at 0.002".
My 125TS runs OK with the lesser clearances.
Max
Postby Ventodue » Tue Jul 28, 2020 9:54 am
veloduke wrote: 0.5 mm is 20 thou (0.020") so I can't see that being right, unless you want to hear the bike coming :) <snip>
Cheers, Max. Thanks for the reply.
Had had the same thought: 0.5mm must = slappy, noisy clearances, I mean. I will pass your advice on.
(I'm surprised not to have seen this enormous discrepancy in the factory literature commented on before ...)
Users browsing this forum: Majestic-12 [Bot] and 131 guests
