Monza Junior Electrics
955Sprint
Hi there. Trying to get my head around the basic electrics. Looking at the wiring diagram there are 7 wires going into the original switch. On mine I have 2 brown wires only so something isn't right and the battery doesn't appear to charge. If engine not running lights don't come on, when running come on with a bit of throttle. Can replace diode with a modern rectifier but might be better to put in a combined rectifier / regulator but still unclear on lighting switch needs?
Re: Monza Junior Electrics
This is the 160 Monza jr. schematic, the wire colours are included. With this you can check all the connections.
A combined R-R might be a better solution, but you have to rearrange some wiring.
955Sprint
Hans, thanks for that. That's a good clear copy of the wiring diagram and I can relate to wiring colours now. Couldn't make it out on the blurred diagram I had
Users browsing this forum: Majestic-12 [Bot] and 79 guests
