450 parts manual on tech section
Postby graeme » Mon Apr 27, 2020 8:24 am
How do I open the parts manual for 450 in the Tech section ?
It's not a pdf
When I try to open it it says something about no Adobe ?
Re: 450 parts manual on tech section
Postby Ventodue » Mon Apr 27, 2020 10:17 am
I 'see' your problem Graeme 8-) . Here's what I get ... (http://www.motoscrubs.com/Ducati_450_Gr ... ent_CI.htm)
Anything particular you're after? I would offer to scan the whole thing for you, but it's 30 odd pages :o.
Btw, it doesn't cover the late 450s, desmo or otherwise. That I have as well, tho' ... ;)
Ciao
Postby graeme » Mon Apr 27, 2020 12:05 pm
Thank you Craig
For now only one thing.
Kick start,
On the shaft outside the case, inside the clutch cover.
Return spring, washer, distance piece (tube) then a “washer.”
Does it say what dimension the washer is ?
I’ll have to make one.
Thank you
Postby ducwiz » Mon Apr 27, 2020 5:04 pm
graeme wrote:How do I open the parts manual for 450 in the Tech section ?
It's not a pdf
Many of the parts books and manual have gone from thr Motoscrubs tech section, forever. Read this:
http://www.motoscrubs.com/forum/viewtopic.php?f=3&t=2144&p=16230
I have a complete catalog for the early 450 models available, and one for the late 450D model, figures of chassis parts only and low resolution. I can send them by email, or place link for download.
Postby ducwiz » Mon Apr 27, 2020 5:05 pm
It's not a pdf
I have a complete catalog for the early 450 models available, and one for the late 450D model, figures of chassis parts only and low resolution. Both are scanned pdf's. I can send them by email, or place link for download.
amartina75
Postby amartina75 » Mon Apr 27, 2020 5:58 pm
18.5 x 25 x 0.5
1966 250 Scrambler
Postby graeme » Mon Apr 27, 2020 9:18 pm
Gentlemen,
Thank you all once again.
I have a section of the parts manual for 450 but it only has bodywork, wheels and the crankshaft assembly.
Thank you again
Postby Ventodue » Tue Apr 28, 2020 9:00 am
Thanks to amartina75 for sorting you out. It's good, this forum :D.
graeme wrote: I have a section of the parts manual for 450 but it only has bodywork, wheels and the crankshaft assembly.
On this particular point, Graeme, you may have noticed that the kickstarter pages that amartina75 scanned are in fact common to all 3 sizes of engine - i.e for these bits, there's no separate parts manual for the 450.
Postby ducwiz » Tue Apr 28, 2020 9:15 am
Comment: The 450 kickstart lever is longer than the others. It has a different part no.
Parts catalogs for download:
https://www.sendspace.com/file/1pcj84
https://www.sendspace.com/file/e330g6
Postby Ventodue » Tue Apr 28, 2020 10:48 am
ducwiz wrote:Comment: The 450 kickstart lever is longer than the others. It has a different part no.
True, true, Hans :) . Good point - wouldn't want anyone to make the mistake that just because the parts book pages are common for all 3 models that the parts that are shown there are too!
Users browsing this forum: Majestic-12 [Bot] and 78 guests
