Hope your all safe and well at this troubling time-
Simple question, are the clearances checked hot or cold?
The amount of information to be found in this site is incredible, thanks to all of you who contribute. This might sound like a strange ask, however, does anybody have a pic of the late DewCatTea Bob?
Thanks and take care
Bob
Mach 1 valve clearance
nalimugmug
nalimugmug
Re: Mach 1 valve clearance
Thanks Graeme.
Bob
Bob
nalimugmug
Hi again,
Posted on this site from the The Ducati workshop manual
Inlet .15mm
Ex .30mm
Mick Walkers book, restoring Ducati singles
Inlet .15mm
Ex .25mm
Which one should I go by?
Bob
Inlet .15mm
Ex .30mm
Inlet .15mm
Ex .25mm
Bob
I used 5 and 7 thou back in the day and the bike was timed at 104mph ,but if you use all the revs a lot the clearances can close up as the valves hammer the seats so you need to keep a check on it.
nalimugmug
Thanks Bevel bob
Bob
Bob
nalimugmug wrote:<snip>
Inlet .15mm
Ex .30mm
The same values are given in the owner's handbook(s)
Users browsing this forum: Google [Bot] and 34 guests
