New member
Minion Dave
New member
Postby Minion Dave » Wed Jan 22, 2020 5:53 pm
Hi just joined the forum as I have just bought a 1965 Ducati to restore I was sold it as a 1965 Daytona but by the engine and frame numbers it appears to be a Mototrans Deluxe it has a 5 speed gearbox any help or spare parts for sale would be appreciated.
My main restorations have been Old British Bikes so certainly need help on this one
Re: New member
Postby ducwiz » Wed Jan 22, 2020 6:19 pm
I can post download links for the 250 de Luxe spare parts list on your request.
cheer Hans
Minion Dave
Re: New member
Postby Minion Dave » Wed Jan 22, 2020 7:00 pm
Thanks Hans that would be great .Dave
Re: New member
Postby Jon Pegler » Wed Jan 22, 2020 7:41 pm
5-speed Mototrans De Luxe was not produced until 1967.
The engine and frame number, or even the original Spanish registration number could help date your machine a bit more accurately.
What parts are you short of?
Re: New member
Postby ducwiz » Wed Jan 22, 2020 9:28 pm
Minion Dave wrote:Thanks Hans that would be great .Dave
Dave,
here http://www.motoscrubs.com/forum/viewtopic.php?t=2652 is an older thread with more information about the 250 deLuxe.
And this list http://www.lamaneta.org/numerochasis/ducati.html might help to identify the bike and its year of mfg.
Posting some photos would be helpful for the Mototrans experts in this forum (i am not one of these).
Minion Dave
Re: New member
Postby Minion Dave » Thu Jan 23, 2020 9:36 am
Thanks Jon I have a authentification letter signed by Roy Bacon saying it is a 1965 Ducati Daytona 249 capacity engine no MD91850MD and frame number MD88264 but when measured bore it was 68mm and couldn’t find that in any of the books I have bought when trying to buy a Conrod kit I was told it must be a Mototrans the tank which needs repair appears to be a Daytona so a complete mystery to me that has spent years on British Bikes.
I need a Conrod kit and a frien who used to race Ducati said just re ring the piston and put back in but I don’t really feel that is the right way.Dave
Minion Dave
Re: New member
Postby Minion Dave » Thu Jan 23, 2020 9:48 am
Sorry Jon it is a 69mm standard piston.Dave
Re: New member
Postby Jon Pegler » Thu Jan 23, 2020 1:54 pm
Your dating letter from Roy Bacon shows how little he knew about Ducati singles.
I would doubt that it would be accepted by the DVLA in the UK now, because it was issued so long ago.
The DVLA usually require a dating letter to be less than one year old nowadays.
From the numbers that you have given, your frame was produced in the middle of 1964, probably July.
The engine is a later 5-speed motor from about 1970.
It is certainly a 250 De Luxe, and the fuel tank is almost an exact copy of the Italian Daytona tank, so it sounds like you have the correct one.
Con rod kits are expensive. Nigel Lacey stocks the Samarin rod kit for the Mototrans 250.
It is similar to the Italian 250 rod kit but uses a different crankpin, so is not interchangeable.
Rod kits can be obtained from Spain slightly cheaper, but the quality is not as good as the Samarin rod.
Jesus Guzman lists rod kits on his Recambio Usado website . Look for Ducati 250 carter estrechio
69mm rings are not easy to find, although Jesus Guzman can probably make up a set from individual rings, or an internet search should produce some results.
Minion Dave
Re: New member
Postby Minion Dave » Thu Jan 23, 2020 7:17 pm
Thank you so much for that info I will let you know how I get on the tank is a bit rotten on bottom so maybe taking it to NorthernRadiators they repair vintage tanks Dave
Re: New member
Postby Ventodue » Fri Jan 24, 2020 10:58 am
Jon Pegler wrote:Your dating letter from Roy Bacon shows how little he knew about Ducati singles.<snip>
:D . Just as well Jon is here ...
(The 'MD' suffixes to the frame and engine numbers tell you straight away it's a Mototrans, not a Bologna bike. So therefore it can't be a Daytona).
Users browsing this forum: No registered users and 202 guests
