Charging issues strada
Dave L
Postby Dave L » Tue Jan 21, 2020 8:51 am
I'm having trouble with the charging system on my 250 Strada. I have fitted a three phase r/r from vehicle wiring products.The battery is not being charged at any rev range. Does anyone have a simple diagram or advise?
Re: Charging issues strada
Postby Ventodue » Tue Jan 21, 2020 9:21 am
While waiting for Jon to come along, here's the Strada wiring diagram.
(Looking at it, I have no reason to think that Strada has anything more than a conventional 3-wire alternator - ?)
veloduke
Postby veloduke » Tue Jan 21, 2020 9:52 am
Hi
Well I guess we have to ask was it ever working?
How are you checking if it's charging - voltmeter?
If you have a multimeter you could check that each of the alternator wires is connected to each other, and that they are not connected to earth.That would be a start.
Are you running 6V or 12V? Have you go the correct regulator for the voltage?
That's probably enought to be getting on with, let us know the outcomes.
Max
Dave L
Postby Dave L » Tue Jan 21, 2020 11:35 am
The battery wasn't charging because the fuse I put between the r/r and the battery wasn't located in the stupid #%£&@ fuse holder properly. Maybe I should just remove the fuse altogether. Thanks for the prompt advise etc.....
veloduke
Postby veloduke » Tue Jan 21, 2020 11:58 am
:D Glad you found the problem!
Max
Postby Ventodue » Wed Jan 22, 2020 9:37 am
Dave L wrote:The battery wasn't charging because the fuse I put between the r/r and the battery wasn't located in the stupid #%£&@ fuse holder properly. Maybe I should just remove the fuse altogether.
Gotta ask .. what are you trying to protect with the fuse? :? Fuses are intended to protect wiring and components against excess current flow. In this situation, I don't really see its function ...
P.s And, as a general rule, the fewer you have, the better :)
Users browsing this forum: No registered users and 238 guests
