Clutch Housing Bearings
etsjw
Postby etsjw » Mon Dec 02, 2019 2:41 pm
Does anyone have a good method for removing the two clutch housing bearings?
The manual drawing shows 2 bearing , 2 spacers, and a Seeger ring. This setup seems to make bearing removal a difficult task.
John
Re: Clutch Housing Bearings
Postby Eldert » Mon Dec 02, 2019 3:15 pm
Hi John
you can move the middle spacer over a little so that you can get a drift behind the bearing and knock it out .
etsjw
Postby etsjw » Mon Dec 02, 2019 8:08 pm
Eldert,
The small inner spacer was stuck in the housing but once I freed it up I was able to move it around in the housing and knock the bearing out.
Used the same procedure on the other bearing by moving the Seeger ring around so I could use the drift on the large spacer.
Thanks much!
John
