Lower Bevel Gears
matzb
Lower Bevel Gears
Postby matzb » Thu Jul 22, 2010 8:58 pm
Are the lower bevel gears and bushing tunnel the same on the wide case and narrow case (interchangeable)?
Re: Lower Bevel Gears
Postby Eldert » Thu Jul 22, 2010 9:11 pm
the lower bevel bushing is the same on narrow and wide case engines .
the bottom bevel gear ( the one with the shaft ) is the same on early widecase engines .
later widecase engines got a bigger rh main bearing . they went from a 6206 to a 6306 bearing .
this bearing is also wider 19 mm instead of 16
so they had to ground a flat on the outside of the bottom bevelgear otherwise the gear would foul the inner race of the bearing
Postby Bevel bob » Fri Jul 23, 2010 3:32 am
Hi Eldert, No doubt you have read the post on bottom bevels, have you had problems with shimming the housing ? how did you go about it?.
