Who do you recommend for cylinder and crank work?
HMBAtrail
Postby HMBAtrail » Sat Aug 24, 2019 12:57 pm
Looking for someone here in the States for a re-bore of the cylinder, tapping the head for a second spark plug and opening up the cam tunnel for a bigger cam, and someone to replace the big end bearing on my crank.
I've had mixed success with some fellas down in Texas and am looking for someone who can do the work right the first time and not take months to do it.
Re: Who do you recommend for cylinder and crank work?
Postby JimF » Sat Aug 24, 2019 6:17 pm
Syds Cycles and DesmoPro are US (Florida) based Ducati bevel specialists.
Postby JimF » Sat Aug 24, 2019 9:52 pm
JimF wrote:Syds Cycles and DesmoPro are US (Florida) based Ducati bevel specialists.
I recall there was a shop in Minnesota too.
I think that we have members of the list that have or work at bevel-knowledgeable shops.
However, you should solicit others here for their reviews of these service providers.
Also, press these providers for expected completion dates. These folks are generally quite busy.
Gianni
Postby Gianni » Sun Aug 25, 2019 3:14 am
Jim, you might be thinking of Wheels unlimited, in Rochester, MN. 507-288-5630
John
Postby double diamond » Sun Aug 25, 2019 3:31 am
Edco in Petaluma, CA would probably do the head work and bore the cylinder. Good work and they deliver when promised.
All you need is the big end bearing replaced? No thrust washers? Rod and pin are ok?
Matt
HMBAtrail
Postby HMBAtrail » Sun Aug 25, 2019 3:46 am
Rod seems OK but I’m contemplating going to an Arrow rod because . . . well . . . because. :)
double diamond wrote:Edco in Petaluma, CA would probably do the head work and bore the cylinder. Good work and they deliver when promised.
Matt
amartina75
Postby amartina75 » Sun Aug 25, 2019 7:25 pm
Syd’s Cycles does all the things you say you’re looking for. Malcolme has rod kits made to his specifications by Falicon. You’d have to ask him about using an Arrow rod. He’s a nice guy and worth talking to either way. I paid about $600 for a rod kit and $300 ish for labor I think when he did my 450 crank several years ago.
1966 250 Scrambler
jbcollier
Postby jbcollier » Mon Sep 09, 2019 11:53 pm
+1 Syd's. They do amazing work. They balanced my 250 and it's as smooth as butter at speed. Shakes like heck at idle but that's single cylinder balancing for you.
jbcollier
Postby jbcollier » Mon Sep 09, 2019 11:54 pm
Oh, and they have jigs to drill for the second plug. Turns out like factory.
