Strada seat
Dave L
Strada seat
Does anyone have a good or v good seat for my Strada (1978)? Every one I've seen so far looks like it's been used as a home for hungry rodents.Im tempted to try and make one myself because the base is half decent.By the way,I solved the leaky fork oil seal problem.I had put the seals in upside down........
Re: Strada seat
Hi Dave,
You might like to consider this:
http://www.lamaneta.org/mercadillo/vent ... num=131375
HTH
HTH
Dave L
Re: Strada seat
Thanks for the link.I have seen this seat and have contacted the seller before but even though it's in very good condition it is larger than a strada seat.I might have too buy it anyway and actually I do have a Forza without a seat as well.There is a very good auto jumble here next weekend so I will keep my fingers crossed......
Re: Strada seat
Hi Dave,
Craig's link looks like a standard Strada seat to me, so should fit OK.
Be aware that the seats from early Forzas will not directly fit onto a Strada.
The Stradas and late Forzas use the thinner seat with the two small cutaways above the rear shock absorber mounts, whereas the early Forza seats are thicker and do not have the cutaways.
The mounting points underneath the two seats are also in a slightly different place. preventing a direct swap between the two.
All these differences was due to the changes to the frame rails when the Strada was first produced in 1978.
The Forzas only got the later frames with the revised starter motor arrangement in 1980.
Dave L
Re: Strada seat
I tried my Forza (1978) seat on the Strada and it won't fit properly, as you said.The seat in the link looks a lot thicker than the damaged one that was on the Strada when I bought it.
Dave L
Re: Strada seat
I've contacted the seller and hopefully will have a seat shortly
Users browsing this forum: Google [Bot] and 56 guests
