I need to convert my 250 4 speed from the leaf spring to the coil spring and brace. I've got the brace but what I need is a spring and the length of the long bolt and spacer. Or if someone has a kit that's not ridiculously priced like the ebay one, I'd buy one.
Thanks!
AK
Kickstarter conversion from the leaf spring
a_kress
AKress
My little Monoster 250 Single http://akress.com/monoster.php
Subscribe to the Motorcycle Road Racing Calendar http://akress.com/
Twitter: a_kress http://twitter.com/a_kress
Instagram: a_kress http://instagram.com/a_kress
PhilR
Re: Kickstarter conversion from the leaf spring
Nigel Lacey does the spring retainer plate, plus lock tab and spring. All you need then is to drill and tap the crankcase for a second fixing, and make two spacers from a bit of thick wall aluminium tube..
a_kress
Thanks Phil.
I'm going to order the spring and lock tab today from Lacey. Any chance you know the length of the longer bolt and spacer?
AKress
a_kress
Thanks Nigel!
I picked up some parts today. Hopefully if the weather warms up a bit I can get back to work on it soon.
AKress
In case you missed it, here's a web page on how to make the kickstart modification:
http://www.motoscrubs.com/Narrowcase_Ki ... Repair.htm
DucMonzter
When I did this conversion, a machinist friend suggested putting a glob of grease on the drill bit and tap to capture the metal shavings....worked great!
Jeff
Jeff
ajleone
