Spark plug options
HMBAtrail
Spark plug options
Postby HMBAtrail » Fri Mar 01, 2019 5:53 pm
For a 350 with a dual plug setup, what plug options are you fellers going with? Yeah, I know it’s very bike specific but a baseline (primarily for the second plug) would be appreciated.
For what it matters, Omega hi Comp Piston, Lacey 277 cam, coil springs, 7mm 40/36 valves, Electrexworld crank mounted ignition, custom exhaust with Cone Engineering silencer.
Re: Spark plug options
Postby double diamond » Wed Mar 06, 2019 6:21 am
C7HSA for the secondary plug. B6HS for the primary.
Matt
Postby LaceyDucati » Wed Mar 06, 2019 10:19 pm
For race use NGK grade 9's both plugs.
Users browsing this forum: Google [Bot] and 138 guests
