con rod kits
briggy
con rod kits
Postby briggy » Tue Dec 04, 2018 3:12 pm
hi I,m rebuilding a 1973 250 mk3 and would like to hear any opinions on the con rod kits available as the price variation is huge and also the pistons. Any advice would be much appreciated Thanks
Re: con rod kits
Postby double diamond » Tue Dec 04, 2018 6:51 pm
Use the search function. There are many, many posts about conrod kits.
Matt
Re: con rod kits
Postby Eldert » Wed Dec 05, 2018 8:05 am
Hi Ian
do you have the engine dismanteld yet ? there are 3 types of widecase crankshafts .
better look first what you have before ordering the wrong BE set
briggy
Re: con rod kits
Postby briggy » Wed Dec 05, 2018 10:07 am
yes engine in bits ,i assume the blanking plug is is the same dia as the crank pin and the crank webs need to be machined for a wider con rod.just not sure if the arrow rods are worth the large amount of extra money .Cant find a lot on google about them
cheers Ian
