More 250 strata probs
Dave L
Postby Dave L » Mon Oct 22, 2018 1:41 pm
Thanks for all the advice so far everyone,much appreciated.Next question! The speedo drive cover plate sits about 3mm inside the hub.Is there supposed to be a shim/washer sitting on the bearing inner race between these two parts? I can't find a washer with these dims(23 outer,15 inner and 3mm thick)
Re: More 250 strata probs
Postby Ventodue » Sat Nov 03, 2018 4:22 pm
I think Jon has already given you a good lead .... :)
"The Strada wheel with a drum brake is the same as an Italian Ducati single, so has the same bearings and spacers etc. "
And so, following that lead, here is the parts diagram for the 250 Monza (and pretty much everything else, frankly). You'll see there are two washers, one felt (#620), one steel (#77.210). (If you've got sealed bearings, you can forget the felt one).
HTH
Postby Ventodue » Sat Nov 03, 2018 5:05 pm
Dave L wrote:I can't find a washer with these dims(23 outer,15 inner and 3mm thick)
If you can't get one made - and I dunno where you are for postage etc - you could always try:
https://www.ebay.com/itm/DUCATI-BEVEL-V ... 0937141374
Listed with the correct part number (0170 77 210) at least ....
