250 strada front wheel
Dave L
I am having difficulty aligning the front wheel of my strada 250 to the forks.It has a drum brake on one side and speedo take off on the other.Can anyone supply a diagram showing shims and washer placement,please?Also,the speedo cable has broken at the gear end and looks as if it originally was attached to the helicoil gear at the factory.Does this means that I have to buy a new cable with new gear attached? If so,where from,cheers,Dave L
Re: 250 strada front wheel
Hi Dave,
The Strada wheel with a drum brake is the same as an Italian Ducati single, so has the same bearings and spacers etc..
Check that the wheel spindle fits easily between the fork legs without the wheel in place, and also that it fits through the hub/brakeplate/ speedo drive cover.
Sometimes things like the bearing spacer move out of line, or the aluminium of the brake plate gets burred over, making it difficult for the wheel spindle to slide through.
If the speedo cable has broken off inside the helical gear it's just a case of pulling it out, although you may have to hold the cable in a vice and pull the gear with a pair of grips to get the broken piece out.
jon
jon
Dave L
Thanks Jon.Do you know the pitch/size for front wheel spindle/axle nut,it's not a standard metric (possibly bsf/af etc?)I can't find one anywhere and it is holding up the whole project
The thread pitch, on a 250Mk3 or Monza, is 1.25mm, the thread dia. is 12mm, which is listed as a metric fine type.
