Hi Folks,
Any tips for removing a seized choke plunger in a Dellorto vhb 29a?
Can it be pushed out after the "choke jet" (directly underneath) is removed?
Stuck choke Dellorto carb
Scottish888
Re: Stuck choke Dellorto carb
Is the plunger cable operated or lever operated?
Scottish888
It is lever/cable operated.
I managed to free it last night, I had soaked in in penetrating fluid overnight, still could not pull the plunger via the cable, then just tapped the plunger lightly from the top, it pulled out easy.
Users browsing this forum: No registered users and 123 guests
