Static ignition timing
syrup head
I have a 1968 5 speed narrow case 250cc Scrambler and I cannot find any reference to the static ignition timing in the manual. Does anybody know how many degrees it should be? Thanks.
Re: Static ignition timing
what automatic advance unit do you have ?
the AA 367 B ( advances 18 degrees ) or the AA 359 ( advances 28 degrees )
I think the units only advance half those amounts but its doubled by the gearing?.
Bevel bob wrote:I think the units only advance half those amounts but its doubled by the gearing?.
so what would be the crankshaft degrees advance then ?
Just looking for clarification Eldert, btw I dont think the crankshaft advances at all,its all done by the advance unit.
The advance and retard units have a code number on them, with a bike of this age anything could be in there and they vary a lot . If the bike has a non std ignition system this may dictate what advance and retard would be the best,and the easiest to live with. More information would help.I'm not even sure a 68 NC scrambler was made.Is it a Spanish made bike?. There are experts on this forum who will help .
You might find your engine no. in this booklet http://www.motoscrubs.com/Ducati_Electrics/Ign_Flywheel.htm. Possibly it helps tpo identify the bike.
Its very likely this is a mototrans built bike, all could be different. Spill the beans.
syrup head
It is an Italian narrow case from 1968, I know they were not supposed to make them but this is one, I have the original Italian log book to prove it.
Does it have a battery?. Does it have points/.
