instruments on the vento are held in place by black rubber rings, which have cracked. Instruments are 75mm diameter. Does anyone know where I could get repalcements?
thanks
replace instrument holder 350 vento?
cooperplace
be nice, I'm not very bright.
Re: replace instrument holder 350 vento?
Jon may be able to help you out. Otherwise, I suspect you're going to have to go second-hand, from Spain. The good news is that they were used on other Mototrans bikes - Forza, and I think Strada and the 500 Twins.
Try the search words, 'Soporte relojes Ducati'. That gives this,for example;
https://www.milanuncios.com/accesorios- ... 045369.htm
(P.s As I guess you know, Ventos only have 3 idiot lights, not 4 as in this example (additional battery charge light). But the instrument rubbers will be the same).
P.p.s This one is NOT Vento, I believe:
http://recambiosducati.com/es/272-cuadr ... desmo.html
HTH
HTH
cooperplace
Users browsing this forum: No registered users and 153 guests
