Greetings,
I'm looking for the 32x39x18 needle roller bearing, but have not found a source in the US. Any sugestions?
Dave
250 Crank Pin Bearing
dsmess
Re: 250 Crank Pin Bearing
Is it a needle roller or Just a caged roller ?.
Hi Dave
i would try this source in Italy . the cage is silverplated .
http://www.thekingofpiston.com/
Hi Dave,
I have new big end bearings. $25 +shipping from southern California. PM me for details.
Matt
Matt
Hi Matt
where in southern CA ? i lived in the Chino / Ontario area for about 10 years
howlndog
BDI Express carries a couple options and can be ordered online. I've used them in the past and their service has been terrific.
https://new.bdiexpress.com/ca/en/Bearings/Roller-Bearings/Needle-Non-Thrust-Roller-Bearings/K32X39X18H/p/1087593
Derek
'70 350 Mark 3D
'70 350 Mark 3D
Hi Eldert,
I'm in Long Beach CA.
Chino has changed a lot. Used to be dairy farms. Now it's housing developments.
Were you racing anything when you were in California? I used to run at Riverside, Ontario, Willow Springs and Sears Point but, obviously, that was a long time ago.
Matt
Matt
dsmess
Thanks for the info!
I have not yet disassembled the crank.
It is from a narrow case M1 engine in storage many years. It was knocking badly and has noticable radial play. From research, I think this crank should have a stepped 27-30mm crankpin
(27mm ends in flywheels). But it does not make sense with the 32x39x18 bearing. It seems with a
30mm pin size at the big end and 3.5mm rollers
The bearing should be 30x37x18.
Help me understand!
Dave
Help me understand!
Dave
Hi Dave
original crankpin is 27 /32 / 27
but if your engine was knocking badly i am thinking a new bearing is not gonne fix the problem .
double diamond wrote:Hi Eldert,
Matt
Hi Matt
i was unloading haytrucks at dairys and feedstores for a living . the only competition i did then was haybucking contests .
Users browsing this forum: No registered users and 37 guests
