Looking for 265 Needle Jet
Vintmoto
Postby Vintmoto » Fri Dec 08, 2017 1:57 pm
Hey Singles Fans,
I am rebuilding a SSI 29d carb and need a 265 Needle Jet that is not worn. If anyone knows where I might be able to locate one, I am willing to pay or trade for it.
Thanks in advance,
Ken
Re: Looking for 265 Needle Jet
Postby ducwiz » Fri Dec 08, 2017 2:32 pm
Vintmoto
Postby Vintmoto » Fri Dec 08, 2017 4:05 pm
They list it as unavailable unless it is because I am in the USA. If someone in Europe could check it it shows stock availble, that would be great. I would be happy to pay someone to purchase it and forward it on to me if it is in deed available.
Postby Ventodue » Sat Dec 09, 2017 9:08 am
Vintmoto
Postby Vintmoto » Sat Dec 09, 2017 12:37 pm
Buzzing only had 270s available. Not sure how much of a difference the step up in size would be. If anyone has more expience with this I would love to hear their insight. I am assuming my 265 Needle jet is worn since the needle showed obvious signs of wear. Which I knew how to measure it to see how far out it really is.
Postby Jordan » Sat Dec 09, 2017 1:47 pm
Normal fix for a slightly worn needle jet is to lower the jet needle to compensate.
Postby Bevel bob » Sat Dec 09, 2017 7:20 pm
I use a 260 and find it to work well in a Tuned 250 Mark3 NC ,and I still get symptoms of richness .
Vintmoto
Postby Vintmoto » Sun Dec 10, 2017 11:56 pm
I suspect going smaller would be fine as well as my bike always ran a litttle rich with the 265 also. Well if anyone has a 260 they would part with, I would be happy with one of those as well.
Postby Bevel bob » Mon Dec 11, 2017 11:54 am
Got my 260 from Australia. I did notice that it has no air bleed hole, I dumped the 265 so it would be helpfull if you could look at your 265 and give measurements for it?, I could try drilling the 260, if it does not help I will just solder it back up.
Vintmoto
Postby Vintmoto » Thu Dec 21, 2017 12:45 pm
Seems it would be a good opportunity for someone to have some made up. Seems like it would be pretty easy. I may look into it once I get a little more time.
Users browsing this forum: No registered users and 108 guests
