Mounting tank
KarstenH
Mounting tank
Postby KarstenH » Fri Oct 13, 2017 4:04 pm
Hello,
i have a question for a Diana.
What did you do between the rearside from the tank and the frame - there must be a upholstering.
How big should be the distance between tank and frame - i want no made scratches and i need place for
wiring and some electrical equipment.
In the parts list is nothing to find...
Has anybody a picture for me?
Regards Karsten
Re: Mounting tank
Postby ducwiz » Fri Oct 13, 2017 4:22 pm
Hi Karsten,
I don't have a spares cat. for the 4speed models, but in the 5speed version a "tank gasket" 0440.83.030 is depicted and it's no. listed, at least for Monza and Mach1. I remember having seen this item, it was a rubber or foam pad, half way wrapped (glued?) around the top tube of the frame. The catalog even gives the dimensions: 70x130x20.
Re: Mounting tank
Postby ranton_rambler » Fri Oct 13, 2017 5:39 pm
In my 175TS book the part number is 175V.SB53 and size is 70x100x20. Is it foam or solid rubber? Mine is missing from the kit of parts I'm trying to make into a bike.
KarstenH
Re: Mounting tank
Postby KarstenH » Fri Oct 13, 2017 6:50 pm
Thank you very much,
now i have an way to solve my problem.
I will use some layers from foamed rubber.
Regards Karsten
Re: Mounting tank
Postby Jon Pegler » Fri Oct 13, 2017 7:08 pm
Part no. 175V.SB53 is the same part as 0440.83.030, just that one is the old numbering system.
The rubber pads used to be made of a foam rubber, not solid.
Re: Mounting tank
Postby Jordan » Sat Oct 14, 2017 12:33 am
A club racer trick is to make one from inner tubes.
Method is to cut several pieces of required length, and stuff one of them with all the others.
The bundle can be roughly moulded to shape and taped to the frame tube.
It's a temporary fix that often never gets upgraded as it is out of sight.
KarstenH
Re: Mounting tank
Postby KarstenH » Sun Oct 29, 2017 10:04 am
I have got now a piece rubber foam
where i must place the polster?
Thanks Karsten
Re: Mounting tank
Postby ranton_rambler » Sun Oct 29, 2017 1:04 pm
My project bike does not have the foam pad but I can see a ghost of where it was on the underneath of the tank. The front edge is about 200mm from the back of the tank. I don't think it's too critical as long as the tank is kept away from the frame tube when fixed down.
nalimugmug
Re: Mounting tank
Postby nalimugmug » Mon Oct 30, 2017 6:09 pm
A couple of pics for you.
Hope this helps
Users browsing this forum: Google [Bot] and 60 guests
