No Serial Number on Motor?
gregwils
Postby gregwils » Sun Dec 11, 2016 2:38 am
I bought a 160 motor about 6-8 weeks ago. The head and cylinder were off and the motor still needs a good cleaning. I just noticed today that there is no serial number on the case. It doesn't appear that the it was ground or sanded off because you can see the original casting marks in that area. Anyone have any thought as to what I have? Thanks.
Greg W
1965 Ducati Monza
1966 Ducati Monza (Project)
1966 Ducati Monza Jr
1986 Porsche 911 Carrera
Pittsburgh, PA USA
Re: No Serial Number on Motor?
Postby Rick » Sun Dec 11, 2016 6:58 pm
Probably a replacement crankcase- the factory sent out replacement cases with no numbers so the shop or owner could stamp the numbers from the damaged cases into the new ones- they would sell individual crankcase halves also, you could look for the numbers on the bottom of the case halves to see if they are a 'matched' pair, or if just one case half was replaced.
gregwils
Postby gregwils » Mon Dec 12, 2016 12:54 am
Thanks, makes sense. I guess the possibility of the one-off, secret experimental race engine worth several million dollars is not high. Sounds like Moe, Larry or Curly simply forgot to stamp the thing when a crappy 60's Italian casting failed. I will look elsewhere for the serial #. Like I said, makes sense. Thanks again.
Greg W
1965 Ducati Monza
Pittsburgh, PA USA
