Help, my 160 came with no front pegs. I am looking for a clear picture of the correct pegs for this bike so I can fabricate them if I cannot find a set.
thanks for your help
Honduc
Monza Junior 160 Foot Pegs
gregwils
Re: Monza Junior 160 Foot Pegs
Here is what the foot pegs look like. If you are a little patient, a set will show up at a reasonable price on fleaBay.
Greg W
1965 Ducati Monza
1966 Ducati Monza (Project)
1966 Ducati Monza Jr
1986 Porsche 911 Carrera
Pittsburgh, PA USA
1965 Ducati Monza
Pittsburgh, PA USA
BDang
Last week I was having a tough time pulling the long bolt off the chassis (to the right). I don't know if it is stock part or not but it was so tight to pull it out while turning the bolt. It has 17mm (socket size if I remember correctly) nut and end. I needed to pull it out so my home-made EX nut removal tool could pass through.
Regards,
Brian
Regards,
Brian
Honduc
Thank you for the picture. I take it the foot rest part is flat, not round?
Madman
They look like they are the same as my 250 mk3. They are flat because they fit footrests that have DUCATI embossed onto them. Like these http://www.smmotorco.com/index.php?main_page=product_info&products_id=11
DesmoDog
The entire bracket is non-round and the same as used on the larger bikes IIRC.
The reason the bolt is hard to remove on the 160 is the frame mounts are bent. They aren't reinforced like the mounts on the 250 and of the few 160s I've looked at they've all been bent.
-Craig
BDang
Frame mount is bent. It's possible, and I will verify this, although it looked straight last time I was working on it. My long bolt seemed to be not a single piece because I thought I see something on its shank looked like it was extended by welding and then grinding.
Regards,
Brian
Regards,
Brian
Users browsing this forum: No registered users and 175 guests
