nuts and bolts
KarstenH
nuts and bolts
Postby KarstenH » Sun Oct 23, 2016 3:20 pm
Hello,
i have a question to the dimensions from nuts and bolts in the parts book.
What ist the difference between the Dimension MA and MB?
Ducati 4 speed monza/diana
8MA x 10,5 part nr. 0400.92.330 engine mount plate
8MB x 12 part nr. 0440.83.010 screw in the extra thread in frame
What material are the screws: steel is clear, what quality, what surface refinement?
Regards Karsten.
Re: nuts and bolts
Postby Rick » Sun Oct 23, 2016 3:45 pm
External threads are MA, internal threads are MB, if I remember right.
Re: nuts and bolts
Postby Jon Pegler » Sun Oct 23, 2016 4:32 pm
MA is standard metric coarse thread, 8mm is x 1.25 pitch
MB is metric fine thread, 8mm is x 1mm pitch
Re: nuts and bolts
Postby Rick » Sun Oct 23, 2016 4:53 pm
I wasn't really sure- found this in a book, but it may be a later standard than used in the 1960s.
KarstenH
Re: nuts and bolts
Postby KarstenH » Tue Oct 25, 2016 9:12 am
Hello Rick, hello Jon,
after extensiv surching in my parts list i found some external threads with MA or MB dimension.
Thats why i agree with Jon - standard thread MA and fine thread MB.
Has anybody some ideas about the surface refinement.
I think zink plated, passivated or galvanised colorless
Karsten
Re: nuts and bolts
Postby Ventodue » Fri Oct 28, 2016 12:58 pm
Jon Pegler wrote:MA is standard metric coarse thread, 8mm is x 1.25 pitch. MB is metric fine thread, 8mm is x 1mm pitch
+1.
KarstenH wrote: Has anybody some ideas about the surface refinement. I think zink plated, passivated or galvanised colorless
The original finish was Cadmium plating. Depending on where you live, Cadmium can be difficult/expensive to get done these days. But Zinc is just as good (maybe try to avoid 'Bright Zinc', aka 'BZP').
DucMonzter
Re: nuts and bolts
Postby DucMonzter » Fri Oct 28, 2016 1:00 pm
Hi Karsten,
If you're referring to the original surface finish on the hardware, I believe they were cadmium plated.
- Jeff
