450 Jupiter Wiring
eddd
450 Jupiter Wiring
Postby eddd » Sun Mar 27, 2016 5:24 pm
Firstly let me introduce myself my name is Mike and this is my first post. Based in south of uk I am currently restoring 450 Scrambler/Jupiter and it goes well. I have hit on a wiring problem, the harness looks all ok but the ignition switch is not isolating the circuit and the electronic ignition in test mode sparks whenever the battery is connected. I have followed the map and can't see a fault but am baffled. Any help from this brill forum much appreciated.
Re: 450 Jupiter Wiring
Postby Jordan » Sun Mar 27, 2016 11:06 pm
Singles with electronic ignition use a particular switch to stop the sparks.
You probably know that, but just mention it in case - it's different from the switch used for points ignition.
In the OFF position, it kills the engine by grounding a wire from the HT coil unit.
The switch may be faulty, or incorrect type, or it's a wiring connection problem.
If a replacement isn't readily available, you can add a separate kill switch, but you won't have the security of a key. (Ha!)
eddd
Postby eddd » Mon Mar 28, 2016 8:54 am
Thanks Jordan I have the sachse 6v ignition and the standard 3 pole replica switch. Do you know of an electronic ignition switch that I can swap to and is it wired differently than the white, blue and light/earth that goes to the 3 pole. Thanks
Mike
Postby Jordan » Mon Mar 28, 2016 11:56 am
(removed)
Postby ducwiz » Mon Mar 28, 2016 12:02 pm
On the Sachse MHP page, I located this schematic: https://www.elektronik-sachse.de/content/diagrams/ducati_350_points.jpg.
It is more elaborate compared to that depicted here: https://www.elektronik-sachse.de/ZDG3/start/header.php?page=3&ver=3.10&typ=Ducati%20250-450%20Mono&path=DUCATI/250_450/&lang=en. Maybe you did not connect the ign. module's input "7" to the white cable (switched Bat+), but directly to the battery?
Postby Jordan » Mon Mar 28, 2016 12:43 pm
Hans shows us the Sasche system is not self-powering, but is powered by the battery.
That's not like the original Ducati/Motoplat CDI schemes, so doesn't need the special switch.
eddd
Postby eddd » Mon Mar 28, 2016 2:15 pm
Thanks for the replies I just put the points back in whilst the battery is connected the points are live. I earthed the ignition switch to a better earth and the earth wire from the battery and the ignition switch got very hot very quickly. So the problem is same points or electronic. When I test the switch with a meter I get com when closed and nothing when open. Struggling for ideas now and the ignition unit goes to the coil
Thanks for the help
Mike
eddd
Postby eddd » Mon Mar 28, 2016 6:46 pm
Having gone through the loom wire by wire with a meter the fault was in the fuse board which had been wired 180 degrees out. Key in switch on spark, switch off no spark. On to the fuel next!!
Mike
