Specialty Tool List?
howlndog
Postby howlndog » Mon Feb 29, 2016 7:25 pm
As I am about to start putting together a '70 350 Mark 3, are there any "must have" tools I should acquire?
Derek
'70 350 Mark 3D
Re: Specialty Tool List?
Postby Ventodue » Tue Mar 01, 2016 1:49 pm
howlndog wrote:As I am about to start putting together a '70 350 Mark 3, are there any "must have" tools I should acquire?
1. Exhaust nut spanner. Various models, but this is the original design. Do NOT try using anything else.
2. Clutch locker. This locks up the engine so you can undo/do up various nuts - cam, crank, clutch. Here you can do better than the original tool(s) by getting a combined tool that locks both the drum and the centre:
3. Flywheel puller, if you need to remove the alternator rotor. Make sure you get the right size: 62mm thread for the wide-cases:
HTH
howlndog
Postby howlndog » Tue Mar 01, 2016 5:09 pm
Craig - excellent, thank you.
derek
Derek
'70 350 Mark 3D
Users browsing this forum: Google [Bot] and 37 guests
