kickstarter return
flanker
kickstarter return
Postby flanker » Wed Feb 10, 2016 3:11 am
Hey guys just finished my rebuild. It fired right up after 4 kicks!!! sounded great too. but the only issue I'm having is the kickstarter does not return back to the upright position i have to do it manually.... Any ideas of how i went wrong. thx rob
Re: kickstarter return
Postby ducwiz » Wed Feb 10, 2016 6:49 pm
Narrow or wide case model?
flanker
Postby flanker » Wed Feb 10, 2016 8:07 pm
Nc! It's starting to come back to parrallel with ground but only sometimes. Here r some pics of build. I may need a stronger spring, but I remember there being a lot of tension when I wound the spring
Postby Eldert » Wed Feb 10, 2016 8:41 pm
Hi Rob
did you try removing a shim behind the cover ?
flanker
Postby flanker » Thu Feb 11, 2016 6:07 am
I think your right. The shim must go. It's running so well except for that. The eldert
Users browsing this forum: Google [Bot] and 112 guests
