W/C Battery
atreyu
W/C Battery
Postby atreyu » Sun Jan 10, 2016 10:30 pm
I'm struggling to find a 12v battery to fit my widecase, using the original rubber strap.
I believe the original battery was 119mm (L) x 83mm (W) x 161mm (H), does anyone know of a 12v battery to suit?
Re: W/C Battery
Postby Jordan » Sun Jan 10, 2016 10:35 pm
I don't know, but did find a useful solution with another bike I own.
I couldn't find a suitable height, but with an AGM battery that can be safely mounted in any position, I found one that fit OK on its side.
Re: W/C Battery
Postby ducwiz » Tue Jan 12, 2016 6:23 pm
If you still have the old dead 6V item, you mây convert it into a perfectly fitting 12V type.
Carefully open the battery and take out all the lead/acid stuff. Immerse this in water and neutralize i. e. with baking soda, then depollute into the usual battery recycling system. Clean the old battery housing thoroughly. Then purchase a 4-cell LiFePO4- battery with 2000-4000 mAh capacity, either a cell block or single cells with special mounting bracket. YOu have to fit the cell array into the old battery case and make some good connections for your main power wires.
Those Lithium-Iron-Phosphate batteries are available on ebay or elsewhere. As their nominal cell voltage is 3.2 V, four of them in series form an excellent replacement for a 12V lead/acid type. No changes are necessary for R-R or alternator, but must be of course 12 Volt types.
http://www.mpoweruk.com/lithiumS.htm has basic info about Lithium-Ion batteries.
This german company http://cs-batteries.de/Oldtimer sells LiFePO4-batteries for motorcycles. The offer only 6V types, but you should send them a request for 12V, maybe you'll be lucky ..
regards Hans
Users browsing this forum: No registered users and 43 guests
