Amal 26mm concentric on a N/C 250
narrow_monza
Postby narrow_monza » Tue Oct 27, 2015 5:17 am
Greetings,
I have an Amal Mk1 26mm carb (model 626/R300AL) fitted on my N/C 250 and would like to get jetting suggestions.
The carb came with the following Amal "factory standard" setting:
3 Cutaway Slide
160 Main Jet
106 Needle Jet
Premier Pilot Jet
Any help would be greatly appreciated.
-Adrian
narrow_monza
Re: Amal 26mm concentric on a N/C 250
Postby narrow_monza » Wed Oct 28, 2015 12:42 am
Anyone?
JJJ12345
Postby JJJ12345 » Thu Oct 29, 2015 11:03 pm
Are you bolting to the spacer or using a manifold? I would like to run one on my nc 250. Thanks. Any pics?
narrow_monza
Postby narrow_monza » Fri Oct 30, 2015 4:26 am
I used a rubber spacer and an aluminum spacer (with fins). It might be overkill and I might go back to just a rubber spacer.
Here's a photo.
JJJ12345
Postby JJJ12345 » Fri Oct 30, 2015 10:11 pm
Looks great. I think I am on the right track.
narrow_monza
Postby narrow_monza » Sat Oct 31, 2015 2:21 am
Be careful not too over-tighten the mounting nuts. These carbs warp very easily.
Users browsing this forum: No registered users and 170 guests
