Cleaning/polishing alloy case
narrow_monza
Postby narrow_monza » Mon Sep 28, 2015 3:43 am
Is it possible to get rid of these dark blotches on the cast part the case without media blasting the surface? They don't appear to be oil/grease stains. Perhaps some sort of corrosion?
Re: Cleaning/polishing alloy case
Postby Jordan » Mon Sep 28, 2015 4:11 am
A wire brush (not drill powered) can improve it.
For difficult to get at corners, I pull some wires out of a normal wire brush, stick them in a copper plumbing tube and hammer them flat to retain, to get a sort of paintbrush style wire brush.
narrow_monza
Postby narrow_monza » Mon Sep 28, 2015 5:51 am
Jordan wrote:A wire brush (not drill powered) can improve it.
Do you use the wire brush dry?
Postby Jordan » Mon Sep 28, 2015 8:55 am
Yes, by hand you can't generate enough heat to be a problem.
You can do lots of damage with a powered rotary wire brush on aluminium.
This is for the unpolished parts only, of course.
Postby JimF » Mon Sep 28, 2015 12:23 pm
http://www.machinerycleanery.com/
I did buy a set of these (the stainless steel brushes, not the nylon ones) but have never really pursued using them. Too busy I guess.
A friend of mine did buy a set for his BSA engine and had good results.
DucRedux
Postby DucRedux » Mon Sep 28, 2015 2:06 pm
I now favor gluing strips of Scotch-Brite abrasive nylon pads, or equivalent, to hand implements like rods, spatulas or hacksaw blade metal to get into difficult places. For example, I have used a hot glue gun and wrapped a pad strip around an old hacksaw blade to fit perfectly in between the cylinder fins. Use a little rubbing compound and the areas polish nicely without diminishing the "cast" appearance of the aluminum. Reheat the implement to remove and replace the abrasive pad. With a little imagination, home made abrasive implements can be fitted onto drills or reciprocating power tools to make the job easier.
narrow_monza
Postby narrow_monza » Tue Sep 29, 2015 1:21 am
This is driving insane. The more I rub using a fine abrasive scotch pad, the darker the stains become.
Postby machten » Tue Sep 29, 2015 10:18 am
Sounds like a you are leaving some scotch pad material on there. I've seen that myself. Id try wetting a rag with carb cleaner or acetone and rubbing it now and see if it lightens Be careful around any paint.
halfpast
Postby halfpast » Tue Sep 29, 2015 11:44 pm
Maybe try a little metal polish after the Scotchbrite treatment? I've had really good results with Mother's Billet polish: http://www.europaparts.com/mothers-bill ... fgodQPAJkQ
Postby Jordan » Wed Sep 30, 2015 3:39 am
I'm not so sure you'd want to polish the unpolished castings.
Users browsing this forum: No registered users and 126 guests
