Hi all, can anybody tell me if the bearing chart in the tech section should be the same for my 200 Elite. I reckon i have a few differences, But maybe someone can reassure me.
Thanks Chris
Bearing Chart>>> 200 Elite
Re: Bearing Chart>>> 200 Elite
Hi Chris,
The bearing chart in the tech section will be correct for a B series Elite motor with the clutch bearings in the clutch itself.
If you have the early A series Elite motor, the clutch bearings are in the cases and are different.
I can't remember the number offhand, but there are two bearings size 30x55x9 .
Chilly
Thanks Jon, I must have an early A series engine then!
Somebody in the past has replaced one of the two bearings with a cheap one labelled USSR, the other is a FAG 16006. And both measure the dimensions you said.
thanks
Chris
thanks
Chris
