Mainshaft oilway roll pin?
Should there be a roll pin here? put in to increase oil pressure towards the cam? but must reduce oil flow to big end?, I have seen pictures of cranks with and without,I have a roll pin in the cam at the bevel end to force more oil to the rockers and this seems a good idea with no downside as the oil gets to the bevels in plenty.
Re: Mainshaft oilway roll pin?
" Should there be a roll pin here? put in to increase oil pressure towards the cam? but must reduce oil flow to big end?, "
____ I believe this is one of two posts in which I've noticed that you have referred to the 'crankshaft', as the "main-shaft" ...
__ I realize that spoken-English -('British') within your great Commonwealth, uses many English-terms differently than we use them here in the USA.
Here we distinguish the three SHAFTs (within the 'bottom-end'), as in the following example...
The CRANK-SHAFT -(with pinion-gear) turns the MAIN-SHAFT -(via basket/primary-gear), which turns the LAY-SHAFT -(via transmission-gears) .
__ Now if you fellas -('blokes' ?) actually refer to the 'crankshaft' as the "mainshaft", then what is YOUR name for the 'main-shaft' ? _ (It can't be 'layshaft', as that would just be out-rightly wrong!)
" I have seen pictures of cranks with and without, "
____ I've also noticed that the right tip-ends of SOME crankshafts & SOME camshafts contain that 'split-pin' -(spring-pin/"roll pin" ?), which seems to have the sole-purpose of partially diverting the oil-flow.
Unfortunately, I myself have never learned the actual-reason for why it's only found in just the places where it's sometimes found. _ And I don't think I've ever seen it pointed-out by any Ducati parts-book.
Hopefully Eldert can shed some light on this issue !
____ I'm sure I had read some-where within this w.site, of somebody asking about removing that particular obstacle from the right tip-end of the crankshaft, so as to increase oil-flow to the con.rod ...
Of course doing that would then cut some of the oil-pressure to the 'top-end' parts. _ So if there's not already a similar split-pin within the right tip-end of the camshaft, then I'd recommend putting one there ! - (So that the cam-lobes & rocker-arms still get about the same oiling as they had before.)
Also as well, since the bearing on the left tip-end of the crankshaft doesn't really need the additional oil-flow which it would then receive (if the split-pin in the RIGHT tip-end is removed), I'd highly suggest inserting a similar split-pin into the left tip-end of the crankshaft.
That way, both the con.rod AND the top-end would then receive additional oil-pressure !
" I have a roll pin in the cam at the bevel end to force more oil to the rockers and this seems a good idea with no downside "
____ I agree !
I've always inserted -(but not quite all the way in!), a tight-fitting split-pin into that location, for my higher-revving projects .
Unfortunately, I've never really tried to remove any such pins (which had happened to have been inserted within the crank's right tip-end) of any of those projects, simply because they were stuck too far inward, (and thus were not easy to be removed), so I never saw enough reason to bother trying.
DUKE-Cheers,
____ I agree !
DUKE-Cheers,
Users browsing this forum: No registered users and 110 guests
