does anyone have any recommendations for these? They can be had on Ebay from around $400 + freight. I mean the type that has a ramp, a table, a clamp for the front wheel, and has a foot-operated jack.
This is just for home use, not commercial. Obviously a lock is needed so it's not held up by the hydraulics. Any reviews from users would be welcomed.
thanks
any experience with motorcycle lift tables?
cooperplace
be nice, I'm not very bright.
Re: any experience with motorcycle lift tables?
Wouldn't work without one. Advice? Well, they're pretty simple affairs
, but:
1. Buy something sturdy (obvious, but probably worth saying
). But not too heavy, either - chances are, you will have to move it around ocassionally.
2. My own uses a hydraulic jack. Don't get one which has the jack 'built in' - if the jack fails, then the table is US.
3. On mine, the table locks in within simple steel pins. Simple, but works (and I like 'simple').
4. Worth getting one with a removeable floor section beneath the rear wheel.
HTH
HTH
Or just make your own for sub AU$100 including removable back wheel floor. You need a portable ramp anyway.
cooperplace
Thanks, I've got one like that, I made it out of timber for about $75, and it's OK but it's a 2-person job to get a bike on or off. With a hydraulic unit, I could lower it, wheel a bike on to it, clamp the front wheel in, and raise it, all by myself, which is what I want to do.
