Removing steering lock
johnavico
Postby johnavico » Sat Oct 11, 2014 11:12 am
Can anyone tell me hovv to remove the steering lock from a 250 Desmo? Needless to say, I don't have the key....
john jupiter
Re: Removing steering lock
Postby john jupiter » Sun Oct 12, 2014 3:16 am
Pound it in and the pin will shear off pretty easily. Comes right out
Postby Jordan » Sun Oct 12, 2014 6:07 am
Make sure the hole in the steering stem is lined up with the steering lock pin, otherwise the lock won't be able to move inwards enough to shear the pin.
A usable tool to hit with a hammer is an 8mm bolt with its head faced flat and turned down to slightly smaller diameter than the lock cylinder.
johnavico
Postby johnavico » Sun Oct 12, 2014 6:15 pm
Thanks guys, all done novv.
No need to vvorry about the steering stem alignment, this is a bare frame novv ready for bead blasting this vveek.
