what type is this washer?
narrow_monza
Postby narrow_monza » Mon May 26, 2014 1:48 am
I'm missing the washer in the attached image (automatic advance unit) so I'm trying to replace it with an equivalent.
The parts catalog describes the washer (0400.46.010) as a "Bent washer".
Is it a wave washer or a conical washer?
-Adrian
Re: what type is this washer?
Postby Ventodue » Mon May 26, 2014 7:47 am
In Italian, it's called a "Rondella curvata", Adrian. English name, 'Curved spring washer'. Looks like this:
Used on many/most of the singles, wide-case included.
(The turned-up edges face into the work-piece, i.e. away from the bolt or screw head. You can always use a dab of Loctite if you're concerned about the bolt coming lose).
narrow_monza
Postby narrow_monza » Mon May 26, 2014 2:04 pm
Got it, thanks!
Users browsing this forum: Google [Bot] and 62 guests
