Sport 48 Restoration
Stan Lipert
Postby Stan Lipert » Thu Jan 30, 2014 4:00 pm
Starting a restoration of a Sport 48, imported from the mother land a few years ago.
Plenty of miles on the crank:
Tiny 38.6mm piston is well worn.
Cracked skirt:
Stan
Northern Ohio Ducati/Triumph
Akron, Ohio
Stan Lipert
Re: Srort 48 Restoration
Postby Stan Lipert » Thu Jan 30, 2014 4:12 pm
Chrome and some paint back in the shop. Love that Kingfisher blue!
Curious forks have no actual oil seals:
Seat is now reupholstered with leather:
Checking out the case finishes:
Postby graeme » Thu Jan 30, 2014 11:25 pm
Is the Cylinder cast iron or alloy?
How did you repair it?
Stan Lipert
Postby Stan Lipert » Fri Jan 31, 2014 11:02 am
Graeme, one piece cast iron, not repaired yet, but will need to be resleeved. Probably a thin wall sleeve.
Postby graeme » Fri Jan 31, 2014 12:24 pm
Thanks Stan.
Is there enough metal to bore the whole thing out to remove all the cracked bits and shrink a thick liner in?
krupp13
Postby krupp13 » Sat Feb 01, 2014 12:21 am
Fantastic Ducati! I have a falcon and this is motivation. Do you know what the differences are between the Sport 48 and the Falcon 50? I would love to find a seat like the Sport 48.
Stan Lipert
Postby Stan Lipert » Mon Feb 03, 2014 10:08 pm
G, a full skirt removal will show light between the fins.
From photos, it looks like the Falcon is more of a scrambler version of the sporty Sport.
SP3
Postby SP3 » Mon Feb 24, 2014 12:07 am
Stopped in for the open house yesterday and the 48 was the first thing that grabbed my eye. Work done thus far (more than pictured here) looks great. Pitty about the plater losing some parts. Keep the updates coming.
1991 851 SP3
1966 250 Monza
1999 Monster 900
1999 Monster 750
1998 ST2
1967 Benelli 250 (MW Riverside)
Stan Lipert
Postby Stan Lipert » Wed Feb 26, 2014 10:53 am
Thanks, ST3.
Did we talk?
I was lucky to find a piston and ring set from Classic Italian Bikes in the Netherlands.
Amazing re-sleeve by Northhampton Crank! The sleeve is a half-thickness thin -wall, if the whole sleeve was bored out, you would see air between the fins!
White CAD parts are back, time to lace the wheels:
Improvised truing stand. The wheel has bicycle type loose ball bearings:
I'm getting ready for chassis assembly, when I get a few more parts back from the chrome plater:
Stan
Stan Lipert
Postby Stan Lipert » Fri Feb 28, 2014 10:14 pm
Shimmed crank for no center case gasket. To test the trans required each shaft to be pulled abutted to it's respective ball-race bearing. The countershaft is pulled by the countershaft sprocket and collar (pull right), a PVC collar was fashioned for the main shaft (pull left).
A drift allows the shift arm to shift through the gears.
Bottom end now together, hand cut base gasket.
The original seat rivets and tabs were white CAD plated, ready to be assembled. Top end ready to run.
Return to “2-Stroke Ducatis”
