Scrambler Borrani Rim Numbers?
Postby graeme » Sat Jan 25, 2014 6:50 am
Anyone know what the Borrani front 19 and rear 18 inch numbers and width should be on a 74 ?
Re: Scrambler Borrani Rim Numbers?
Postby Eldert » Sat Jan 25, 2014 1:14 pm
Hi Graeme
the front is the same as the blue/gold Mark3 a 19 inch WM2 with 4741 drilling code
the rear is the same as a RT 4626 WM3 and 36 spoke not to confuse with a 4626/1 with is a 40 spoke rim for the 750 Sport rear brakedrum
Regards Eldert
Postby Ventodue » Sat Jan 25, 2014 1:17 pm
According to Massimo Clarke, Graeme, they were the same as fitted on the (drum-braked) Desmo and Mark 3.* In which case, I think the sizes are:
19 x 1.85(WM2) x 36
18 x 1.85(WM2) x 36.
Sorry, don't know the Borrani codes. You could try asking Howard at Disco Volante, seeing as he's a Borrani importer - Howard's on this Forum. But for what it's worth, the parts book I have for the 1974 Mark 3 says that the Ducati part numbers should be:
Front: 0682.77.104
Back: 0682.80.100
* Initially, I thought this couldn't be right for the front one, the Scrambler one being 19"; but I see that Mick Walker says that the 73-74 Mark 3 used a 19" wheel.
HTH
Postby graeme » Sun Jan 26, 2014 1:51 am
Thank you gentlemen that what I needed.
Postby graeme » Tue Jan 28, 2014 6:28 am
Hello Eldert,
Thank you for your earlier answer.
Now I have been wondering about the drilling code you mentioned. Does 4741 tell a rim maker what angle to drill a non drilled rim?
And how does the /1 change the drilling from a 4626 to a 4626/1 ?
Are you able to tell me this?
I'm interested to know, not that I will need to do any drilling, just interested.
Postby Eldert » Tue Jan 28, 2014 7:35 am
Hi Graeme
i dont have a clue how they come up with the codes.
i think it is Borrani that came up with the codes
