450 RT re-build
450 RT re-build
Postby Ventodue » Tue Feb 26, 2013 5:07 pm
Nice topic, with photos, of a guy re-building his 450 RT flat tracker over on Ducati.ms.
In action ..
Reason for the re-build .. :o
Go:
http://www.ducati.ms/forums/14-vintage/ ... oject.html
Re: 450 RT re-build
Postby LaceyDucati » Tue Feb 26, 2013 8:01 pm
That's a pattern rod, saving a few hundred £/$ especially in a completion engine is a false economy. That goes for pistons too! The limitation of some of these products has been known since the 60's/70's. This picture is probably a good (if not painful) stark reminder for new owners to Ducati singles and a reminder to all. It's even more important these days as the supply of cases etc grows thinner.
joe46ho
Re: 450 RT re-build
Postby joe46ho » Wed Feb 27, 2013 6:43 pm
Is that a mazzucelli rod ? Or do you know ?
Joe
Too many projects to list...
12 Ducati singles currently
Re: 450 RT re-build
Postby Ventodue » Wed Feb 27, 2013 8:41 pm
LaceyDucati wrote:That's a pattern rod, saving a few hundred £/$ especially in a completion engine is a false economy.
Yeh, but to be fair, he does 'fess up to that ... :shock: :oops:
(Good piccie, tho', eh Nigel ? :D )
Re: 450 RT re-build
Postby LaceyDucati » Wed Feb 27, 2013 9:00 pm
Joe
I'm not sure, looks similar but looking at the broken bits it may have had more than one oil hole in the small end. The mazzucelli rods I have seen have one hole in the top. When you look at these kits there isn’t much material around the small end.
Yes it is a great pic :-)
joe46ho
Re: 450 RT re-build
Postby joe46ho » Wed Feb 27, 2013 11:04 pm
The Mazzucelli Rod I have here has 3 oil holes in it, but in the WORST possible location, this is a 250/350 rod though, not a 450 w/c rod like Craig has here. I think the biggest problem with these rods is the design of the small end, and the oil hole location... this has been discussed a while back in another thread, i had posted a picture of the rod i have in that thread. I got this one for free with some other parts, and i dont intend to use it. I am not an engineer but if you look at the oil hole location, and the thin profile on the small end bore, it is no wonder they break, and if you look at
Craig's pic here you can see they break right at the centerline of the poorly positioned oiling holes. Eldert had mentioned this also, as being the weakest point of these rods, when i asked if anyone had any info on the one i got in a parts lot-buy. Probably a good idea to stay away from these...
Joe
Re: 450 RT re-build
Postby graeme » Wed Feb 27, 2013 11:51 pm
I recently fitted this rod kit to an RT.
Now I'm not sure if this is the same rod as the pictured broken one, but the holes seem to be the same,,,,,,
I looked on the web for MEC EUR and found it was made by a company that makes Vespa parts.
Is this the rod in question? :oops: :oops: :oops: :cry: :cry: :cry:
joe46ho
Re: 450 RT re-build
Postby joe46ho » Thu Feb 28, 2013 12:12 am
Yes, That is the very same rod, I will include a picture of the one i have... As you can see it has the same logo, I am not sure if these are Mazzucelli, or MEC EUR, but I think that is one in the same. Here is a link to a "scooter" shop that sells these rods.
http://www.sip-scootershop.com/Products ... tails.aspx
One thing i will say though is i have been told by a few sources that these would be ok for a restoration that is ridden around town and not "beat" or raced. For what its worth...
Eldert would know more specific info on these.
Here is a pic of the one i have.
Sam
Re: 450 RT re-build
Postby Sam » Fri Mar 01, 2013 7:10 am
I picked up a nice rod kit from a man in Italy looks the same profile as Carrillo. I thought the std Ducati rod looked weak compared to this one.
WHA'S LIKE US
DAMN FEW AND THEY'RE A'DEID
Re: 450 RT re-build
Postby graeme » Fri Mar 01, 2013 7:22 am
Hi Sam, yes I know,,,,,,,,,,,, :oops: :oops:
It won't stay in the RT long and I'll think before having too much fun until then.
