primary pinion and woodruff key on Ducati single
rospo
Hi. Me again. Is the primary drive helical pinion on my 450 Ducati supposed to have a recessed interior? I can't see the point unless the previous owner was into some weight saving. If that is normal, what size of woodruff key goes into the shaft / pinion? Which work better: tab washers or spring-type washers? Hope someone can help here. Thanks in anticipation. Ross
Re: primary pinion and woodruff key on Ducati single
Hi, pinion gear is sold as standard. The half moon key is 4mm
graeme wrote:The half moon key is 4mm
And available from Nigel Lacey - along with the correct tab washer. And a new nut ... and shims, should you need 'em
P.s I think there may be a shoulder machined on the inside of the pinion -? Tsk! Can't remember now ...
recessed interior ? do you mean the oil groove thats machined in there .
joe46ho
I believe, as Eldert has already mentioned, you must be refering to the oil grove... It IS supposed to be there, and as far as I know is there on all Ducati single primary gears... As for the washers, I use the original tab washers myself, some claim the "spring" or bellville washers are the way to go, to each his own I guess... Here are some pics of a primary gear up close, the factory drawings can be deceiving at times...
Joe
Joe
Too many projects to list...
12 Ducati singles currently
rospo
Mine seems to be bigger than just an oil groove. I know the previous owner did quite a lot of work on the engine. Thanks for your help. I am going to try again with a tab-washer.
Users browsing this forum: No registered users and 88 guests
